will 6.0 head work?
will 6.0 head work?
2002 Avalanche - Stock for now
6.0L heads would not be good for ur 5.3 that will drop ur compression too low that ur gonna run like crap def not worth it, prob the best thing is to ethier buy some 243 heads and send them in to get milled down and smoothed out or like red said send ur heads to get ported for more air flow on ur 5.3 heads
05 Silverado cc LQ9, 220 220 .581/.581 114+1 LSA, Pacesetters with Ory, TBSS Intake w/ 90mm TB, Comp roller Lifters, LS7 1.80 rockers, LS1 Heads, Transgo HD2, Vette servo, 160 stat, custom 3inch exhaust, and Nelson Tuned:
5400lbs- 13.62 at 100.46mph - Dynoed at 360rwhp - 375rwtq
5.3L heads actually work really damn well. Go have the heads polished/cleaned up, have it decked so the mating surfaces are true, have a 3-angle valve job performed, and have them fully balance your valvetrain.
If not, have the same thing done to some 243s (they flow slightly better than the 317s), but have them do a minimal porting. Then have the deck milled mack down to keep the CR close to stock.
What are you planning on doing--staying N/A or going FI?????
balance the valvetrain? Thats a new one on me, what do they do?![]()
Balancing means that they operatively engage each valve (intake and exhaust) to account for manufacturing tolerances and other factors, by balancing the motion of the valves (opening and closing) because of the addition of the stiffer aftermarket springs. Once the valvetrain is balanced, it provides a smoother functioning and operating setup.![]()
Where do I meet this snake-oil salesman. Never heard of such a thing. Have any documentation showing gains with the whale blubber additive?![]()
wow balanced valve train so you mean that my valve train that moves at 10k RPM is not working that well and making good power casue its not balanced... lmao what ever...
i am with greg on this one snake-oil
I am gonna be a new Daddy...
Drive it like you live hard and fast....
'91 rcsb, 4.3 V6, 700R4 trans swap, 4/6 drop rolling on 18's, roll pan, 2" cowl hood, electric fan, TBI injector spacer, K&N filter replacement, flowmaster muffler...
[Today 08:09 AM] ChevyLee: dale would make a awesome dad in law too
02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
