I'm only doing bolt on's for now. Whats the best, least exspensive head I can use. eventually I will do a small cam and It would be great if the head would work with that also.
2002 Avalanche - Stock for now
Take your heads off and send them to WCCH, site sponsor, and they'll make them as good as they can for what you can afford to pay.
Tyler's Sister!!!![]()
what about 243's
05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
243s would help but defintly wont be a major change because you will have better flowing heads but you will be lowering your compression so it evens out, at least thats what happened to me lol hope this helps good luck
05 Silverado cc LQ9, 220 220 .581/.581 114+1 LSA, Pacesetters with Ory, TBSS Intake w/ 90mm TB, Comp roller Lifters, LS7 1.80 rockers, LS1 Heads, Transgo HD2, Vette servo, 160 stat, custom 3inch exhaust, and Nelson Tuned:
5400lbs- 13.62 at 100.46mph - Dynoed at 360rwhp - 375rwtq
best head for the money.... Tyler's mom... cheap (close to free) and she travels to YOU!!!!
(otherwise what red said WCCH)
DamnYankee: my nana failed
do you know the casting #
