Results 1 to 10 of 13
Thread: Oil Pan kit question
    Nov 2010
    Coldspring, TX.
    Anybody used this kit in a truck? Just wondering if it will fit an LS6 going into a '99 RCSB 2wd truck.
    GM 19212593
    http://sdparts.com/details/gm-factor...parts/19212593
    Nov 2010
    Coldspring, TX.
    Anybody?
    Visually it looks to me like it would work.
    That looks like the truck pan.
    I bet ya most guys just use the truck pan for ls in most muscle cars. So yeah that's probably what that is.
    Oct 2003
    I know the Camaro(F-Body) pan fits perfect in a OBS LS install.
    San Antonio, TX
    I'd use the camaro fbody pan, the truck pan is too low, may cause issues.
    here is one, gm hi tech just called it an ls1 oil pan in their latest issue, so i'm assuming it's an fbody pan.
    it show dimensions as well, http://www.jegs.com/i/GM+Performance...12593/10002/-1
    ls oil pan
    ls oil pan
    thats the same one in the first post just expensiver
    only on the ends. Put a bead in the corner where the gasket meets up with the pan gaskets, about 1/8" diameter will do it.
