Results 1 to 10 of 30
Thread: my 60' didnt change
    Gramercy
    Question my 60' didnt change
    well, i have 4:10s now and im still running the SAME DRs i did when i was on 3:42s. i launched the same way, and tried new ways. NOTHING CHANGED. i had a consistent 1.84 on 3:42s and now all i can get is a dang 1.82 60'
    my cam calls for a looser converter but i dont feel like upgrading bc i DD it and i love the way it runs now. well, all i can figure is it's bc ive out grown my converter and its a must to get a 3400-3600.
    i went from 3:42s/G80 then to Yukon 4:11s/Tru-Trac. i ran the same psi as last time 26-27ish. i can't understand why it has no real change in the 60'. it E.T. was 13.0 AGAIN, but 104.2ish mph vs the 103.8 i had before.
    2008 GMC CCSB 6.2/6L80e swap
    Could it be due to the heat?
    Gramercy
    i figured i would have atleast seen a better 60' i wish it would have went 1.8 ATLEAST. then i really wouldnt be unhappy.
    the truck pulls retarded fast from 25+
    it keeps up with my buddys CCSB 5.3/6spd/3:42/spec'd cam/Roush tvs1900/obx 1 5/8" LTs/ory almost bumper to bumper from a 25 punch to 100
    gears arent gonna put the power to the ground so why would it gain you any in the 60 ft? a stall puts the power to the ground which gains you 60 ft gears = mile per hour stall = 60 ft
    Simple: 408 on steroids!
    single digits coming soon!
    Gramercy
    i figured it'd be less of a load on the truck so it'd start to move faster which in turn brings my 60' down a lil more ? i dunno, looks like its time for a 3600
    casey23 Guest
    well
    sure its not some of it in the tune?... I think the gears should have helped.... I "help" a guy over the phone out of state... his truck was able to gain a Solid .2X in the .60 foot just going from a 3.73 to a 4.10... But yes he has a Bit more converter then yourself..... and YES a converter will help you .....
    Gramercy
    yeah i have a Circle D 3000-3200 (278mm) the truck does better on a flat foot than a 3200 foot brake. its ok it saves me gas jj. i guess its time to run a 3600 converter (brand unknown) im leaning towards the Circle D or a Yank. i want to upgrade to Billet 1-2 and 4th gear servos, a Tru-cool 40k
    Birmingham, AL
    Quote Originally Posted by casey23 View Post
    dang!! .2 in the 60' alone! truck must have a ton of torque! big motor huh?
    01 Silverado
    Jan 2005
    Humble/Houston TX
    what was the dates of the 2 runs? and what track were they done at? are you dead hooking or spinning some out of the hole?
    old mod list: H/C/I/N/E/G 408
    Plainfield, IL
    dibs on your current verter if you get a new one lol
