Results 1 to 10 of 30
Thread: my 60' didnt change
    casey23 Guest
    well
    sure its not some of it in the tune?... I think the gears should have helped.... I "help" a guy over the phone out of state... his truck was able to gain a Solid .2X in the .60 foot just going from a 3.73 to a 4.10... But yes he has a Bit more converter then yourself..... and YES a converter will help you .....
    Gramercy
    yeah i have a Circle D 3000-3200 (278mm) the truck does better on a flat foot than a 3200 foot brake. its ok it saves me gas jj. i guess its time to run a 3600 converter (brand unknown) im leaning towards the Circle D or a Yank. i want to upgrade to Billet 1-2 and 4th gear servos, a Tru-cool 40k
    2008 GMC CCSB 6.2/6L80e swap
    Birmingham, AL
    Quote Originally Posted by casey23 View Post
    dang!! .2 in the 60' alone! truck must have a ton of torque! big motor huh?
    01 Silverado
    Jan 2005
    Humble/Houston TX
    what was the dates of the 2 runs? and what track were they done at? are you dead hooking or spinning some out of the hole?
    old mod list: H/C/I/N/E/G 408
    Plainfield, IL
    dibs on your current verter if you get a new one lol
    Gramercy
    i cant remember the date of the first run but i can post up when i get home.
    this last run was this past wed night at No Problem Raceway in louisiana i have no idea the town bc there is NO ONE around the track lol.
    the other run on 3:42s was at State Capital Raceway outside of Baton Rouge, La. they both had the same temps really. 95-97ish both races.
    im dead hooking on a flat foot, 1500 stall up, 1800ish stall up, 2000 stall. the 60' ranges from 1.82-1.86 if i stall it up to 2500+ it 60's 2.0 no matter what! im running M&H DR 275/55/16s and they are awsome imo. i noticed when i swapped tires my bump stops was about an inch from the perches, well when i swapped tires last night i cut them all the way off just incase i was bottoming out on them.
    Oct 2008
    Sounds like you need a little more stall. Do you have a way to data log it. You can see the flash RPM then to see what is really going on.
    Chris
    Visit us on Facebook
    Please fill out my Ask Chris form for converter recommendations.
    http://www.circledspecialties.com
    Gramercy
    i dont have hptuners, but i have an old efi life scan cable from my 01 but ill be getting with my tuner to data log it at the track for me. i need to get with you about a 3600 converter. i think that's going to be my next upgrade vs 1 7/8" LTs and 3.5" exhaust.
