Results 1 to 10 of 20
Thread: gas gauge quit working....
    wichita falls, tx
    well a few days ago i did somethin dumb and took my neg battery cable off and my key was on.
    when i put the battery cable back on and the gas gauge is stuck on ''E''
    So today i changed the sending unit in the tank today and that didnt fix it, so i swapped gauge clusters thinkin the stepper motor on the gas gauge went out but that wasnt it either...now im out of ideas...HELP
    Intro Radicalli's
    Wiring issue.
    At least you have a lift.
    Nov 2009
    chicago, il
    Fuse/relay?
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    wichita falls, tx
    Is there a fuse for the gas gauge? I checked alot of fuses and found nothin....also swapped the drl relay and the fuel relay and still nothin
    Thanks for the suggestions lemme know if yall think of anything else
    Intro Radicalli's
    wichita falls, tx
    Is the gas gauge controlled by the PCM???
    Intro Radicalli's
    Quote Originally Posted by banker099 View Post
    I believe it is. You pop'd something.
    So you changed the fuel sending unit?
    Gauge cluster?
    Since you did both of those already, its going to be either a loose ground or some fuse / relay is dead. (IMO)
    No fuse or relay. Gauge is commanded by PCM.
    Wiring issue as stated before. Only other possible is a bad "new" part.
    GA
    had the same problem. never got it fixed and it drove me crazy
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Nov 2009
    chicago, il
    If it's controlled by the pcm, maybe you sent a voltage spike through the wiring for the gauge into the pcm and toasted it. Find and check the wires to the pcm, and see if they're doing what they're supposed to be doing?
    wichita falls, tx
    Quote Originally Posted by ChevyLee View Post
    Gauge cluster?
    yep changed the sending unit and the gauge cluster...im thinking it is a fuse i missed or a pcm problem
    could be a bad new part, i dont think its a wiring problems since it was working fine before i disconnected the battery
    Quote Originally Posted by truckinL33 View Post
    i got a buddy with an 02 pcm ill stick it in and see if it fixes it....ill keep yall posted and thanks again for the help!
    Intro Radicalli's
