Originally Posted by banker099 Is the gas gauge controlled by the PCM??? I believe it is. You pop'd something. So you changed the fuel sending unit? Gauge cluster? Since you did both of those already, its going to be either a loose ground or some fuse / relay is dead. (IMO)
