Hey people.
I have a 2001 Tahoe with the ordinary 5.3L.
After sending the PCM (mail order) tune back a couple times to W4M Performance and the truck still not starting I gave up on the cam and yanked it back out last night.
I have 241 Cast LS1 heads on the block that I'm about to pull off in a couple hours and just go back to stock so I'll have something to drive till then.
Anyways, I have a code reader and it's not pulling any codes.. But when I go to start the truck it sounds like it wants to try but as soon as I let off the key back to the ON position it stalls.
I replaced:
All four O2 sensors..
MAP sensor..
MAF sensor..
TPS sensor..
IAC valve..
Cam sensor..
Crank sensor..
Third set of spark plugs..
Plug wires..
Second set of coil packs..
Changed out exhaust flange gaskets..
AND still no luck..After I put the stock heads back on I'll give it another shot since I just realized that I lowered the compression ratio with the 5.7L heads.
Any thoughts?
Thanks!!
P.S - I'll sell the heads for 300 and the cam for 400 if anybody is interested.
I'll pay shipping
