Does anybody know the max ithe 5.3 can be bored out to? I know you can go to the 5.7 and use LS1 internals is this the max?
Thanks in advance.
Joshua
Thanks in advance.
Joshua
you cant safely go more than 3.90. It is a different casting than the 6.0, so it will not take the 4.0 bore.
yeah, i heard that you shouldnt go beyond 5.7 because of the thickness of the cylinder walls
02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
cool, thx guys.
somewhere on here the is a write up by someone (Allen i think) that shows where you can turn a 5.3 into a 383 stroker
DamnYankee: my nana failed
Allen = Farmtruc
yeah sorry Allen = farmtruc.... aka head honcho.... aka the man the myth the legend....
I think its a bored out 5.3L with a stroker crank. Yes you can do a 383, but you will need to change the internals.
12 Sec. Club! SOLD
SOLD***
