Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 46
Thread: Victor Setup?
    Jun 2007
    Victor Setup?
    im in the middle of trying too figure out what to do about an intake setup.im looking at the victor setups or similar im open for sugg.my question is ,what do you doo with all the stuff that you have installed on youre ls1 intake ,sensor ets..cause they obviously dont fit on that intake.i see that you get the intake with inj ports so thats ok,and i wanna use a elbow with a 90 mm tb..just open fo r discussion and opinions on how too do and make it work right on my setup.pics threads etc.fill me in guys.
    Oct 2007
    Bandera, TX
    I have the intake and elbow that Im puting on my 6.0, I will be doing the swap soon. I will keep it updated
    single digit street truck
    for build info
    Keep an eye on Casey's buildup, he's using the aluminum 4 barrel type intake, 90 degree elbow and 90mm TB. His is going together very soon.
    Jun 2007
    yeh guys pleasedo let me know or take pics so ican do mine with ease thank you .
    intake
    90 mm
    6.0 LQ9
    works well on a 6.0 i first had it installed by TRT on a 5.3 just felt like something wasnt right, i wanted to stay N/A and then i ran across an awesome deal on a LQ9 and wanted to up the compression so i pulled my patriot stage 2 heads off 706 casting and installed them on the 6.0 raised the compression up to around 11:5:1 but not really not foresure on that number but i know its over 11:1 was rather easy set up, i run 42 # injectors dont know where the duty cycle is just yet, but will find out soon enough..as for hooking it up it was rather easy.. i can take more pics if you like to show you wher everything hooked up at if you like ...
    Simple: 408 on steroids!
    single digits coming soon!
    wow, talk about restriction. That 90mm needs the elbow opened up quite a bit, doesn't it!
    correct red, actually you cant see it but it had a spacer between throttle body and elbow, which i didnt use, just something i made when i was on nights at work, but the elbow was redone, i'll see if i can find the pic.. where the air intake is flush all the way around .
    casey23 Guest
    Vic pics
    Jun 2007
    skeet and casey , beautifull setups ,i want this and i am going to do it ,skeet can you post the other pics for me i want too know what to do with the plug in stuff all over the intakes .i dont know the names of the sensors right this second but specifficully the ones on top of the factory intake1 in front on top 1 in back under the cover plate ,etc ,do you delete these somehow or do you have to figure ou anather place to put them.?i want the same setup can i do it with mine truck the way it is .whats it take ?these harness plug ins what do you do with them?i know the intake and tb setup looks easy enough to install.i need the details though b4 i order parts.or if i need part i dont see.will dbw tb b ok?thanks for more pics and all the in fo ,im excited too do this i wanna stert ordering parts now.nice job guy looks great.
    Oct 2007
    connecticut
    ok, u guys know what im about to ask, will this work on my truck, or is it more suited to forced induction? im looking for any new upgrades that benefit performance and look really cool under the hood, and that setup looks awsome. im willing to do any upgrades that might have to go with the conversion. any input even negative, would be helpful.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
