Results 1 to 9 of 9
Thread: Mass Air Flow
    Jun 2007
    maine
    Mass Air Flow
    Heys i wanted to hear some opinions on MAF's. Should i buy a factory MAF or some kid of aftermarket. i will be buying a bored TB duno if that makes a difference. thanks!
    stay factory
    yep stay factory if you dont you could have problems.
    Apr 2005
    +1 on factory.
    Gone, but not forgotten!
    An aftermarket MAF is the biggest waste of money--it will only cause tuning issues and will constantly have your CEL to come on... De-screening a MAF is also a bad idea. Like everyone else said--stay factory!
    Jun 2007
    maine
    buying one on ebay a bad idea?
    Oct 2007
    connecticut
    so maybe i should get a new factory maf with the screen huh? i took my screen out about 4 years ago and hit the little resistors in the process. oops
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    The guys having problems with descreened MAF units are not getting their PCM retuned. They read posts about descreening the sensor and see the validity of more air flow but fail to follow through with a tune. They fail to realize part of the reason the screen is there is to provide a linear/non-tumbling air flow past the sensor wires. The sensor is designed with the linear flow in mind. When you change that characteristic you have to update the tune to compensate. Scan a vehicle before descreening and then scan again after descreening (without retuning) and you will see the fuel mixture go lean.
    Jun 2007
    maine
    do yall know what a new maf from a gm dealer runs?? is ebay a bad idea for these? thanks
