Quote Originally Posted by droopyzda1 View Post
Cross reference the '95 fuel pump to the '96 V8 fuel pump. It maybe the same. I have the motor and trans in. I used dirty dingo mounts, so the trans is in the same spot as it was with the 4.3. Driveshaft bolted it up. I removed the bed to change the fuel pump so since the bed was off, it was a lot easier for me to put the lowering shackles, hangers and lowering shocks. All accessories are bolted up. I modded the 4.3 A/C compressor bracket to fit on the 5.3 so I can retain the original C1500 compressor. Radiator and electric fans are in. PCM is reprogrammed from the guy at lt1swap.com . Now I am working on the harness. At the rate that I am going, it should be running in a couple weeks. It has been 6 months since I started the swap. I can see the light at the end of the tunnel, finally !!
Thanks for the info, and sounds like its comming along quite nicely what schocks did you use becase im looking for some for mine as well I have a 3/6in. Drop
