Results 1 to 10 of 19
Thread: 95 v6 swap questions
    Sep 2012
    Quakertown, Pa.
    Here's a pic of typical plates. There are many out there, depending on what you want to spend. These plates are used in conjunction with the original "clamshell" mounts from the small block. I'm not sure if your V-6 was equipped with them, but I believe the mounting bolt pattern was the same on either the V-6 or V-8.
    I have read here on this site that the plates will need to be clearanced a little to clear a mounting boss cast into the LS engine block. Nothing a grinder can't take care of.
    http://www.ebay.com/itm/Trans-Dapt-4...e9233a&vxp=mtr
    http://www.ebay.com/itm/LS-engine-sw...517878&vxp=mtr
    http://www.ebay.com/itm/LS-LSX-Engin...5762d3&vxp=mtr
    John
    Aug 2013
    Quote Originally Posted by Mickeymotormount View Post
    Thanks I orders the motor mounts if they don't work or if I don't like them ill just swap the clamshells to the v8
