Cross reference the '95 fuel pump to the '96 V8 fuel pump. It maybe the same. I have the motor and trans in. I used dirty dingo mounts, so the trans is in the same spot as it was with the 4.3. Driveshaft bolted it up. I removed the bed to change the fuel pump so since the bed was off, it was a lot easier for me to put the lowering shackles, hangers and lowering shocks. All accessories are bolted up. I modded the 4.3 A/C compressor bracket to fit on the 5.3 so I can retain the original C1500 compressor. Radiator and electric fans are in. PCM is reprogrammed from the guy at lt1swap.com . Now I am working on the harness. At the rate that I am going, it should be running in a couple weeks. It has been 6 months since I started the swap. I can see the light at the end of the tunnel, finally !!
