Results 1 to 10 of 10
Thread: WTB 3/4 ton/14 bolt SF spring anchor plates and top u bolt spacers
    I used the 1/2 plates when I went 14 bolt, had to grind the radius out a little bit but they worked fine even with me hitting a 300 shot on them.
    how was the center to center spacing on the plates for use on the bigger tube....or you must have used the 1/2 ton ubolts??
    '93 Chevy Sport... LS2...T56 Magnum..."Red Rider" under construction.........
