Results 1 to 10 of 13
Thread: Traction control/stabilitrac
    Aug 2004
    Magnolia, TX
    The only way to completely disable it is to pull the three Stabilitrac and ABS fuses. Even holding the button 5 seconds doesn't completely disable it.
    Bummer! I already pulled fuses 59 and 60 from under the hood and seemed to disable the system. Do you happen to know the third fuse? Thanks!
    Quote Originally Posted by 2k5Squirrel View Post
    Those two alone may disable it. Did it throw codes or anything when you did it? I haven't tried it, only going on what I've read. I want to say 37, but thats just off the top of my head and sounds right. May be completely off base.
    Aug 2004
    Magnolia, TX
    Cluster looks like a dang Christmas tree. ABS, brake, TC dummy lights. TC and stabilitrac messages in the driver info center.
    Okeechobee, Fl
    Out of complete curiosity why do u want to completely disable it?
    49 Ford F1
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by 11 6.2 View Post
    I don't want it, lol. I got stuck on Saturday because of it. Like I said, even when you hold the button down, it doesn't fully disable the system. It's almost like it won't let you spin over 3000 rpms even when its "disabled"
    Okeechobee, Fl
    Haha dang good reason!lol hell the other day I was cruising down the road and one of my friends told me to rev mine up so I popped it in nutral and it wouldn't let me rev it over 3k
    49 Ford F1
    It causes mine to stay in gear too long if its spinning. I've hit 7400 RPM because of it more than once. With it off (hold button), it doesn't happen as often. At the track in Feb I'll pull the fuses and see what happens.
