Results 1 to 10 of 13
Thread: Traction control/stabilitrac
    Aug 2004
    Magnolia, TX
    Yes. 1 tap for TC. 5 second hold for stabilitrac. But it still doesn't fully disengage the system!
    Yes indeed he can. Hptuners is awesome like that.
    No he can't.
    Quote Originally Posted by 2k5Squirrel View Post
    The only way to completely disable it is to pull the three Stabilitrac and ABS fuses. Even holding the button 5 seconds doesn't completely disable it.
    Aug 2004
    Magnolia, TX
    Bummer! I already pulled fuses 59 and 60 from under the hood and seemed to disable the system. Do you happen to know the third fuse? Thanks!
    Those two alone may disable it. Did it throw codes or anything when you did it? I haven't tried it, only going on what I've read. I want to say 37, but thats just off the top of my head and sounds right. May be completely off base.
    Aug 2004
    Magnolia, TX
    Cluster looks like a dang Christmas tree. ABS, brake, TC dummy lights. TC and stabilitrac messages in the driver info center.
    Okeechobee, Fl
    Out of complete curiosity why do u want to completely disable it?
    49 Ford F1
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by 11 6.2 View Post
    I don't want it, lol. I got stuck on Saturday because of it. Like I said, even when you hold the button down, it doesn't fully disable the system. It's almost like it won't let you spin over 3000 rpms even when its "disabled"
