Mine is bad to the bone, I love it.
I just want to adapt the oil pressure one to read fuel pressure.....I hope it works. !!!
I wonder if you can use an Autometer gauge hooked up to the PLX?
from the plx website...
The PLX Oil Pressure Sensor Module accurately measures the the pressure of oil. This is ideal for oil pressure monitoring. Up to 32 Sensor Modules can be daisy chained together in the iMFD system. The Oil Pressure Sensor Module can also be used as a stand alone unit capable of interfacing with 3rd party hardware.
The included sensor is designed for oil pressure sensing ONLY. DO NOT use this sensor with fuel, as the sensor will damage due to corrosion over time.
