Results 1 to 10 of 18
Thread: PlX Gauges who uses them
    Feb 2011
    cleveland
    I want to order a wide band and a few others. Anyone using this Gauge http://tunertools.com/proddetail.asp...PLX-DM6-SMAFR2
    If so how do you like it?
    Sep 2011
    I have one and it works.. I would just make sure you can adapt it to work with your tuning software if you tune your own truck. If all your doing is monitoring afr it works great. I had an lm-1 in the tail pipe and the plx in the downpipe and they read the same on the dyno.
    i got one .its badass,and well worth the 200
    i use it and i luv it
    Simple: 408 on steroids!
    single digits coming soon!
    Apr 2011
    Jennings, louisiana
    Quote Originally Posted by skeet View Post
    X2 mine was point for point with a 1000+ unit on a mustang dyno..
    slowly getting somewhere, 12.75 @ 105 1.77 60', 414rwhp/417rwtq
    Mar 2007
    Mine is bad to the bone, I love it.
    I just want to adapt the oil pressure one to read fuel pressure.....I hope it works. !!!
    did y'all mount the sensor as recommended by PLX, on top of the pipe and top of the sensor pointed 15 degrees forward? I dont have room for that unless I go way back behind the cab. Also, who is datalogging with HPTUNERS with the PLX? They only have one wire for the datalog output and HPTUNERS requires two wires to the box.
    Oct 2008
    The second wire is a ground. Ground it to body should work fine.
    Jun 2004
    george west texas
    allen grounded one wire and has only one in cab wire to tune on the fly with mine...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    you would think that if it were that easy that the HPTUNERS box would have that built in?
