Results 1 to 10 of 12
Thread: wastegate plumbing, nothin special
    The Garage
    For the longest time I've hated the way my truck sounded at WOT simply due to having the wastegate dumped to atmo. I went to a local muffler shop and had this done. Sounds WAY better - actually sounds like a turbo now instead of an annoyingly loud hissing sound.
    haha I loved how mine sounded vented to the atmosphere. Like a jet
    Pittsburgh, PA
    a wastegate should never be merged into the exhaust as a 90*. With any airflow merger its always best to stay with direction of flow as best as possible.
    Since the two pressure are at different rates they can cause turbulance and also effect back pressure. it can also cause boost creep
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jun 2010
    baxley,ga
    is it better to have the wastegate vented to atmosphere?
    04 rcsb forged 347
    The Garage
    Quote Originally Posted by gavin05 View Post
    Not sure. I just plumbed the gate back into the exhaust pipe cuz I didn't like the way it sounded with the gate vented to atmo.
    The Garage
    It does kinda look like that due to the camera orientation. Can't really tell from the pics, but it actually merges at a much lower angle. I know better than to do stuff like this
    Pittsburgh, PA
    youll make more power with a WG vented to atmosphere but that isnt always the case for ppl. merging it around a 45* angle works the best
    412 Motorsports
    The Garage
    youll make more power with a WG vented to atmosphere. merging it around a 45* angle works the best
    Is that because the pressures of the turbine and WG discharges don't have to fight each other? If so, it makes sense.
    That's what all the books say and in theory, it is best, and probably does work better in an ideal world, but in the actual world, I haven't seen it affect a turbo kit at all.
    I built the first few kits with an angled downpipe for the wg, then decided on a 90deg entry, same results on both kits and same back pressure on both kits.
    Check out the single log kits that are around, no way is that wg in the ideal spot lol, being so far down and on only one side of the engine, on the crossover tube, but it does work and controls boost rather well.
    I'm sure at an extreme power level it does make a difference.
    Pittsburgh, PA
    look at this way, anything can work but what works more effeicent? if your going thru hassle of building something why not do it properly instead of having any later second guessing? ive seen it where it has created issues with back pressure where loss of power
    with the position of WG on the crossover style setups. it may seem as its only truely venting that one side of motor however in a boosted application all tubing prior to turbo is at pressure. so youll have some pressure from the one bank backing up and exiting as well as the driver's bank [well say]. ideal? no but its hard to get WG ideal position every time. But merger can be hard to overcome as well but if you have the opportunity then might as well do it correctly.
    or all else vent it to atmosphere, my last setup i ran a muffler specificially for the wastegate, this helped get rid of the awful noise and made it more of a jet setup
    412 Motorsports
