back pressure will cause issues for sure along with vibrations, improper installation. Kyle has had kits out for awhile now. Mics is only one that failed, so whats that tell you? Also none of Kyles older kits failed. i minic'd Kyles setup and my crossover is still being used today along with Kyle's manifold. that was using a one of the heaviest T4 turbos around to. my crossover didnt use any gussets or anything for strength
also that setup that fail didnt make language for power either, hight back pressure issues will restrain a setup from making its full potential on power, along with other things
up till jared i had made the most power with a Kyle manifold/style setup. but i also reconfigured the dyno to read that high, not that a pt88 at 16psi wont make any numbers either...............so a kbracing setup is more then capable of producing over 1k hp in the right hands, in the wrong hands then youll have issues
good job Kyle for making big power with fence post for tubing
