Or think of it this way.......
The old 3.8 V6 from Olds/Buick cars is almost the same as a 5.0 V8 with 2 fewer cylinders.
3.8 = .6333333 L per cylinder
5.0 = .625 L per cylinder
So, if you can imagine the difference between those 2 motors, that's roughly the difference an extra 1.2L makes. Not exactly, mind you, just a point for comparison.
The 1.2L difference in going from a V6 to a V8 in my comparison would actually be a bit less dramatic than a 1.2L larger V8......because in the V6 to V8 scenario, part of the HP increase will also be absorbed by the larger rotating mass of the extra 2 cylinders. You will probably add rotating mass with a larger V8 as well (larger pistons), but not as much as 2 whole extra cylinders' worth. One way to get around, or at least somewhat mitigate the increased rotating mass issue is to use lightweight forged pistons in the larger motor. That of course requires rebalancing of the whole rotating assembly, yadda yadda yadda.
'02 Avalanche 1500 Z-71, BFG All-Terrains, K&N FIPK, Superchips tuner (Nelson eventually), 750-watt Alpine stereo W/ JL midgate Stealthbox.
'88 Mustang GT, 400HP on motor, T-56 6-speed, 3.73s, 150HP NOS
'89 K5 Blazer 1500, blown motor and transmission. Another project some year.
'95 Polaris 600XCR snowmobile, pipes, heads, bored carbs.
If you are only looking for a 13 you can keep what you have and mod it, BUT like everyone once you get to a goal you will set another... So your 13 will become a 12... and so on. I vote save your wallet later down the road and go 6.0 I still wish I did!
im in the same boat, im working on getting a 2004 lq9 6.0 out of a ss truck with 44k miles. trying to get it for $1200. should be a nice step up from the 5.3 maybe get a nice set of l92 heads and raunchy cam with a decent shot of nitrous. with a 6 speed manual if i cant destroy all of 3rd gear and some of 4th with my 20's ill be very surprised. ill keep you posted.
