Originally Posted by
mean05
a 5 gallon cell is a little overkill for a dedicated fuel system, i only run about a 1 gallon fuel cell on my systems and along with the 255 FP you will also need a fuel pressure regulator
Here's my old setup i have already done another setup like this in the truck as of last week again....work flawlessly.
Hey bud, I already have an extra battery where your fuel cell is located at..
So, do you use a IN-LINE fuel pump in your setup?? Cause the one I ordered from NP it's a IN-TANK fuel pump.. That's my concern, how will I be able to hold it still in a 5gal fuel cell..
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
