Fuel cell & walbro 255?
Hey guys, I just bought a walbro in-tank 255 fuel pump from NP, but I just came up with a diff idea, I'm thinking on buying a 5 gal fuel cell and TRY to install the walbro FP in the cell, then have a relay and a switch to activate the walbro in the fuel cell whenever I want to run with nitrous, this is because I use VP fuel when I use the nitrous and is a waste of $ and gas to add VP to my tank and not race.. That's why I would like to have a separate fuel cell.. Do any of you have any suggestion on how should I make the install, or if you think this will not work please let me know..
Thanks in advance!
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
