Results 1 to 10 of 44
Thread: 07 LQ9 w/5 miles on it-$1,900
    Quote Originally Posted by MidnightRider View Post
    That would be a LS2 there is no such thing as an aluminum block LQ9--thats iron block only.
    +1
    that would be a LS2 there is no such thing as a alluminum block LQ9 thats ironblock only
    +1
    How much Money you want to bet? He looked the numbers up cause I didn't believe him either and it was an aluminum block, I do know what L92 heads are, and I've seen a L92 truck intake also. Maybe GM made a mut.
    Could it be a 5.3L block from an SSR or a LS1/LS6 block, maybe LS2 or L76? If it has L92 heads on it chances are pretty high its not an originally shortblock, also. I know, lets tear that dog apart and see what's inside.
    I thought the NNBS vmax came with the alum lq9?
    Quote Originally Posted by DBTBSS View Post
    How much you got....BOY?!?!?! THERE IS NO ALUMINUM BLOCK LQ9.
    Ok, Greg makes a good point....the Holden L76 is a 6.0L aluminum block motor. It IS NOT AN LQ9. This motor has not been sold in the US until recently when Pontiac introduced it in the G8.
    wrong the 2007 NNBS chevy and gmc vmax come with a lq9 6.0 L76 or L92 heads. and yes an all alum block.
    Oh btw yes this is one heck of a deal.........
    Quote Originally Posted by ChevyLee View Post
    Thank You...That is what it was out of. I believe they made an alum block 5.3L for the vmax also, not sure about the heads the used on it.
    Oct 2007
    Bandera, TX
    i will let yall know when i go get it......
    single digit street truck
    for build info
    Spring, Texas
    What all is involved in making this thing low compression? Just heads and pistons? Looking for a motor to build and this one seems like a good deal!
    Quote Originally Posted by TurboMic View Post
    I'll take a Bud Light for the finders fee...I hope it works out and yes let me know when you get it.
    Quote Originally Posted by ramair2002 View Post
    I think the compression is around 10.3 to 1. CNC port the L92 heads to 75cc chambers and that should put you in the upper 9 to 1 CR.
