Quote Originally Posted by bluecajun5.3 View Post
that's a good start.
what i think is happening is in the heat the pcm is pulling timing out the hole b/c of high iat's causing your 60' to be so low. figure if you could get them down to 1.8's that's 4/10's you pick up in the 1/4 easy.
What RPM are you launching at?
