Results 1 to 4 of 4
Thread: Very rattley passenger door
    May 2005
    Well , my truck is now the lucky age of 13 and still hauling ass ! But the passenger door sounds like it's going to fly open at times when I drive down the glass smooth roads of New Orleans ! I've looked at the striker post , if that's what it's called in the doorjamb and it looks ok . Does this sound like a worn out latch assembly ? I'm expecting this to be a dealer item , right ? Thanks guys
    dealer or salvage yard item. Can also buy it through Classic Industries or any aftermark company such as that.
    May 2005
    Thanks Red ,so is it most likely something in the latch assembly that's bad?
    Check the bushings in the hinges, also. If they are worn the striker/latch will rattle, also. What condition are the seals in? They help to keep the door tight.
    I believe there is plastic molded around the latch and it get brittle and breaks away slowly.
