Results 1 to 10 of 19
Thread: TB size
    Oct 2005
    drinking your alcohol
    does anyone know the size of the Throttle Body inlet...... i found something im going to try and need to know the size... its raining outside and im not really wanting to get out...
    also is the MAF really needed... i know thats dumb and really is needed... but i found a c5 short ram air intake that i want to modify a little... its under $50 and figured i would take a shot at it...
    DamnYankee: my nana failed
    Oct 2005
    cmon people someone has to know.... is it 3.5 inches?? thats what i see on alot of TB's, but not sure about ours
    Jun 2004
    george west texas
    i think the tb is 78mm and yes you can run without the maf...have allen sd tune your truck...he's running his av in sd....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Mar 2006
    Mesquite
    What's your plans man....tell me, tell me....
    Jan 2006
    <div class='quotetop'>QUOTE(bud8fan &#064; Jan 13 2007, 07&#58;47 PM) [snapback]79653[/snapback]</div>
    i think the tb is 78mm and yes you can run without the maf...have allen sd tune your truck...he&#39;s running his av in sd....
    I AM RUNNING AN S/D TUNE ALSO.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Oct 2005
    sorry i didnt specify.... i meant outside diameter.... i found an air intake that i could possibly use, but has a 3.5 inch coupler that connects the intake to the TB
    Yeah the inside is like 78mm but the outside is about 3-7/8"(edited to correct diameter). Do you need to know the exact size? I can grab a set of calipers and measure it for you. I think I posted the sizes here a few years ago. Where were you? Don&#39;t you remember?
    Oct 2005
    well i guess ill go ahead and buy it ... if it works cool, if not then i can thow it back on ebay or use it for parts
    Here, found it for you. Don&#39;t say I don&#39;t ever do anything to help.
    http://forum.ls1truck.com/index.php?s=&amp...ost&p=10488
    Mar 2006
    Mesquite
    Surely you could persuade a 3½" coupling over a 3-9/16" TB....
