i was just wondering if they were any good, and which inlet oulet i need for my 05 CC? or if you can suggest something good.
i have the super 40 on my 02 and the 40(not the deltaflow) on my wifes 04. i like how they sound imo. but they tend to drone inside the cab.
you con go with 2.5 or 3in inlet. do you want siingle or duel exit?
04 Grand Prix GTP
03 Z71 wanting a Turbo ,Stall, and Tune BAD
THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
Not trying to sway you, but have you heard the IMCO extremes? Sound awesome.
2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
Flowmasters can have a serious drown depending on how the whole exhaust system is done.
Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
EL JEFE
ROUGHNECK
I've used Flowmasters on my last two systems. The first one was a 3" single tube straight through the center and had no turn down. It dumped right in front of the axle and droned like nobody's business. I added a 90 degree turnout to exit in front of the RR tire and the drone went away. The next system had true duals running to a (2) port 2.25 inlet x (2) port 2.25 outlet and the tone was very nice, no rumble. I think the biggest problem guys have with these mufflers is not exiting the exhaust properly.
Mine sounds awesome. I have a 4 inch intake and dueled out the back with 2.25 straight out the rear and corvette style tips and the only drone it has is when the humidity is up and i am going 70 down the highway with the windows up. Now at 80 the drone goes away but this could be the roar of the motor that is covering it up.
2004 EXC Silverado 6.2L
Mods:
6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
<div class='quotetop'>QUOTE(Blackdog @ Dec 3 2006, 09:41 PM) [snapback]75281[/snapback]</div>i had flowmasters 40 series and then changed to imco extreme and ill never go back to flows....imco rocksNot trying to sway you, but have you heard the IMCO extremes? Sound awesome.
[/b]![]()
2001 seirra 5.3L ex cab.-- 93 performance Nelson Tune,longtube pacesetter headers, ory, magnaflow with electric cut out, airaid cai, throttle body spacer, clear corners, 1400 watt system, 2 ifinity tens custom boxes, panasonic head unit, punch grill....sold :-(
09 camry se v6....gotta have a gas saver while in college...still gets up and goes tho
<div class='quotetop'>QUOTE(blackout00 @ Dec 7 2006, 10:21 AM) [snapback]75621[/snapback]</div>how much did it run ya ? does it have a nice tone and rummble to it when you give it gasi had flowmasters 40 series and then changed to imco extreme and ill never go back to flows....imco rocks
04 Grand Prix GTP
<div class='quotetop'>QUOTE(02CHEV @ Dec 7 2006, 07:35 PM) [snapback]75663[/snapback]</div>mine was only like 62 bucks shipped to my door.....yes very nice rumble http://www.hileri.com/?pageid=50844 thats where i bought mine 48 bucks plus shipping....ships fast.....its a great price for a great product...how much did it run ya ? does it have a nice tone and rummble to it when you give it gas
