Results 1 to 10 of 16
Thread: I need some help??
    Nov 2006
    Im not getting to much out of the other Truck Forums, so I will try here..
    I put the new tranny in my truck and it is having all sorts of issues.. It wont shift into 2nd manually and it wont downshift into 2nd either driving down the road.. What do you think it is ??
    Mike-
    -2000 GMC Sierra
    -1972 Camaro
    -1962 C-10
    -2007 GSXR 750
    -2003 GSXR Alstare 600?
    http://farm3.static.flickr.com/2221/...e4b04eb2_o.png
    You do have the speedo sensor in and it's working okay? The large electrical plug in making good contact? Next question, put it in OD and accelerate, does it shift good through all gears? Is the lockup working in the torque convertor properly? When in OD, if at about 45 mph will it downshift to 2nd gear if you floor it?
    Nov 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Nov 29 2006, 08&#58;07 PM) [snapback]74915[/snapback]</div>
    You do have the speedo sensor in and it&#39;s working okay? The large electrical plug in making good contact? Next question, put it in OD and accelerate, does it shift good through all gears? Is the lockup working in the torque convertor properly? When in OD, if at about 45 mph will it downshift to 2nd gear if you floor it?
    It does everything but ..
    NO&#33;&#33;&#33;
    Also, it wont go into 2nd if I manaully do it while im rolling ..
    Mike-
    -2000 GMC Sierra
    -1972 Camaro
    -1962 C-10
    -2007 GSXR 750
    Sounds like a valve body problem or the 2-4 servo assembly was done incorrectly. Valve body... the 3-2 downshift valve may be stuck or the 4-3 sequence valve body channel may be blocked. Servo... cover retaining omitted or left out, 4th gear apply piston damaged or misassembled, servo inner housing damaged or misassembled.
    Nov 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Nov 29 2006, 08&#58;26 PM) [snapback]74921[/snapback]</div>
    OH Great&#33;&#33; Sounds like alot of shit that can go wrong ..
    Mike-
    -2000 GMC Sierra
    -1972 Camaro
    -1962 C-10
    -2007 GSXR 750
    Jun 2005
    Round Rock
    Who built your tranny??? Local?
    Nov 2006
    <div class='quotetop'>QUOTE(jethro_3 &#064; Nov 29 2006, 08&#58;37 PM) [snapback]74927[/snapback]</div>
    yeah, a guy I have do all my trannys... This is my first 4L60e I had him do...
    Mike-
    -2000 GMC Sierra
    -1972 Camaro
    -1962 C-10
    -2007 GSXR 750
    I&#39;d sure take it back to him. If he has a scanner he can narrow it down. They hook into the OBD2 port and put the transmission through its paces to see if everything is working correctly.
    Jul 2006
    College Station, TX
    When i had my guy but my shift kit in he busted a seal on the 2-3 servo and it would not shift in or out of 2nd.
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
    Nov 2006
    Thanks for the help, I will bring this info to him and see what he is going to do ..
    Mike-
    -2000 GMC Sierra
    -1972 Camaro
    -1962 C-10
    -2007 GSXR 750
