Results 1 to 10 of 29
Thread: Ennis Friday night...
    Mar 2006
    Mesquite
    OK, I'm definitely in town this week so I'm going to finally be able to make it down to Ennis Friday night and see how it does in the 1/4.
    Anyone else interested in going?
    I had a question also...I know we don't really need to do burnouts on street tires, but on the launch, is the track prepped so traction isn't an issue at the staging lane, or am I going to be breaking the tires loose if I just mash the pedal? I plan on running a few different ways, but just want to know what to expect.
    The track should be prepped pretty good. Motorplex knows good starts. I'd air down the tires to 15 lbs.
    Dec 2003
    Newark, Tx.
    You dont really need to smoke the tires, but I would do a small burnout to clean them off and dry them out if you go through the water.
    Oct 2005
    drinking your alcohol
    im down to go if the weather is gonna be nice..... i knwo its gonna be nasty at some point later in the week starting thursday night..... but its spose to be cold thurs and fri so if its dry ill meet up with you out in M-Town and roll out
    DamnYankee: my nana failed
    Apr 2005
    I won't make any promises I can't keep, but, I'll certainly try! I'm going to do an install out in New Jersey on Thursday and might be able to wind it up early enough Friday to get out there Friday night.
    Where do you want to meet at out there if I can make it? If I'm able to make it, I'll retry the truck since that terrible 14.6 ..... I'm certain it will be the only dark blue one with a wide tan stripe down the sides.
    Hope to see you there....would be good to meet you!
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Oct 10 2006, 08&#58;49 PM) [snapback]68749[/snapback]</div>
    The track should be prepped pretty good. Motorplex knows good starts. I&#39;d air down the tires to 15 lbs.
    Thanks Greg. I&#39;ll probably do my first run "as is" - just like I drive it on the street. Then I&#39;ll start adjusting tire pressure, 2wd/AWD, etc.
    <div class='quotetop'>QUOTE(trtturbo &#064; Oct 10 2006, 10&#58;28 PM) [snapback]68779[/snapback]</div>
    Cool..I&#39;ll try not to get &#39;em wet and just see what the big lug will do.
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Oct 10 2006, 10&#58;46 PM) [snapback]68781[/snapback]</div>
    It&#39;s supposed to be low 60&#39;s til about 9:00 then dip into the high 50&#39;s with a 10% chance of precip...perfect....&#33;
    <div class='quotetop'>QUOTE(93Ext5.7ltr &#064; Oct 11 2006, 10&#58;52 AM) [snapback]68830[/snapback]</div>
    I won&#39;t make any promises I can&#39;t keep, but, I&#39;ll certainly try&#33; I&#39;m going to do an install out in New Jersey on Thursday and might be able to wind it up early enough Friday to get out there Friday night.
    Where do you want to meet at out there if I can make it? If I&#39;m able to make it, I&#39;ll retry the truck since that terrible 14.6 ..... I&#39;m certain it will be the only dark blue one with a wide tan stripe down the sides.
    Hope to see you there....would be good to meet you&#33;
    Yeah if anyone decides to go down from the DFW area, let me know and we&#39;ll meet up somewhere convenient for everyone.
    "terribile 14.6"...man I hope I beat that now&#33;
    Oct 2005
    as long as its not raining or the old lady doesnt have plans im in... i can meet you in mesquite
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Oct 11 2006, 05&#58;13 PM) [snapback]68898[/snapback]</div>
    Sounds good. Just post on here sometime if you&#39;re going or not and we&#39;ll meet up somewhere.
    Mar 2006
    Mesquite
    Probably my last post before going to Ennis tomorrow night, so if anyone wanted to meet up, drop me an email (mozecollins@gmail.com).
    Apr 2005
    Looks like I&#39;ll be there&#33;&#33;
    93 Ext Cab w/ 99&#39; LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
