Results 1 to 10 of 13
Thread: cold air intake whats better
    Sep 2006
    Coon Rapids, MN
    need some help on wich intake i should go with. aem, k&n, trueflow or any other
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jan 2006
    I had an AEM that worked pretty good. Now though the STS Turbo is much better.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    volant w/ ram air
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    May 2006
    Waco TX
    I have the K & N Cold Air and it works pretty good. They are all good. You can only get so much air flow and cooling with a filter dont expect huge gains from any of them
    May 2006
    i have one of those &#036;25 filters from Pepboys. it sounds nice but i dont think it does much. but it cleared up the engine compartment cuz i took out the old filter box. i should get a real intake soon
    DBYRD Guest
    go volant, u get performance and looks that none of the others ive seen offers.
    Jun 2005
    Cumming, GA
    <div class='quotetop'>QUOTE(Allstar55566 &#064; Nov 4 2006, 03&#58;09 PM) [snapback]72213[/snapback]</div>
    I dunno, I like the looks of my K&N. Whatever you get, though, I&#39;d get it with a plastic tube; the metal ones are heat magnets.
    Also, before you buy, check eBay; I think I saved like &#036;60 on mine over retail.
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    Oct 2005
    drinking your alcohol
    DamnYankee: my nana failed
    COWL&#39;s induction was stolen from his storage shed. Friggin theives, string them up by their scrotums.
    DBYRD Guest
    <div class='quotetop'>QUOTE(BlenderWizard &#064; Nov 4 2006, 02&#58;12 PM) [snapback]72214[/snapback]</div>
    im not saying it looks bad, but IMO volant is the stuff.
