Results 1 to 10 of 12
Thread: starting dyno numbers for twin turbo
    Dec 2003
    Newark, Tx.
    Well, so far so good. Car survived the first set of dyno runs. car made 589rwhp and 520rwtq.
    This was at just 14 degrees of timing and lifting at 5800rpm. We are out of fuel pump.
    With more pump and 4-6 degrees of timing we should be all over 620- 640 at just 10psi.
    After that, we are bumping the boost a little to get around 700rwhp. This is on pump gas too.
    So far the car is performing great!!
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(trtturbo &#064; Sep 28 2006, 04&#58;50 PM) [snapback]67004[/snapback]</div>
    So far the car is performing great&#33;&#33;
    sweet. Hey, I&#39;m keeping my camera with me Billy so the next time I&#39;m in the area, we can shoot a video of it.
    Dec 2003
    Newark, Tx.
    Well, I hope to have the 2nd pump on soon to get done with it.
    Until then, if you are around, come on by.
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(trtturbo &#064; Sep 28 2006, 05&#58;25 PM) [snapback]67017[/snapback]</div>
    Will do. I&#39;ve got a survey to do over on Hulen, but I&#39;m not driving over there just for the one. So it may be next week.
    San Marcos Texas
    What fuel setup you planning? Hey congrats on the dyno numbers, those sound great. Makes me want to turn up the boost a bit&#33;
    Dec 2003
    Newark, Tx.
    now, it has a single Bosch 044 pump which is good to around 700 at the crank. What I&#39;m plannin is to do a second 044 and run dual feed lines; one to each rail. That should be more than enough. 75lb injectors, so no issue there.
    I think the numbers are right on for 10psi and small cubic inches, especially with only 14 degrees of timing.
    Jun 2004
    george west texas
    thats good billy...nice to see some numbers outta that thing
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Dec 2003
    Newark, Tx.
    just spoke to the owner. Going with the 2nd pump and twin feed lines.
    That will take care of the fuel problems.
    Dec 2005
    Awesome numbers for pump gas Billy&#33; How high are you going to be able to go with boost on that thing?
    http://i76.photobucket.com/albums/j1...o/789547ee.jpg
    1999 Silverado LS RCSB 5.3 Liter (16.02@83.5 bone stock) (with mods ??.?? @ ?)
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11&#39;s, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
