Results 1 to 10 of 20
Thread: Duramax in a obs,regcab
    San Antonio, TX
    What do you guys think?
    How about a new duramax with an 80e? I'm sure the 80E is possible with the right converter and flywheel, and I know it will hold.
    I think there was an article a while back where a company did this. It was in a regcab truck 1/2 ton.
    This think would be crazy!
    Jun 2006
    The Socialist Union of Canada
    I would love to see that.
    Dec 2003
    Newark, Tx.
    Allen, that would be great. It seems so easy to get crazy power out of the Duramax. I bet it would be an expensive swap, but unbelieveable when done.
    I've heard talk of doing it but everyone says don't because of how heavy it is. The 1/2 frame won't hold up to the massive weight and torque. It's what I've heard, not what I know.
    DBYRD Guest
    that would be sweet, is the 80e that great? if so im feeling more comfortable about putting it in my truck.
    Aug 2006
    LaCrosse, WI
    I would love to see it done. I think it'd get a whole lot of attention, and very do-able.
    '82 C-10......project truck.....
    San Antonio, TX
    hey red, maybe some additional crossmembers, supports and beefy susupension, then it may hold up.
    I'm no where near getting started, but it would be awesome and I've had my eye open for a good inexpensive engine.
    Obviously we aren't keeping you busy enough.
    Feb 2004
    Sour Lake Tx
    There is a 6.5l 1/2 ton z71 out here where i live. They came from the factory like that too. This isnt the frist one i have seen either so maybe asside from stiffer front springs and suspension pieces i dont think the weight will be a problem considering that the 6.5 probably out weighs the d max by a little bit since the dmax has aluminum heads. Ill look at my buddys truck, hes got a 1 ton waiting to put in a rebuilt 6.5l I have a 1/2 ton truck waiting for me to get off my ass and build a motor for it so i will look today and see the differences in the two frames. Im sure if any difference the front crossmembers will be different. You can solve that with a 4x4 frame though. That would be cool to see a d max in a 1/2 ton 4x4. 4 wheel burnouts! you will probably need 4wd just to keep the tires from spinning or put 20" wide tires in the rear. 4wd or not i think it would be a smokin fast truck
    Oh, one more thing. the turbo might have to be relocated cause it might hit the firewall.
    EATIN' FORDS AND TUNDRAS
    RIP 2005 VHO ecsb 6.0HO, Comp Cam, Nelson Tune, OBX LT's.
    Jan 2006
    <div class='quotetop'>QUOTE(badseed91 &#064; Sep 25 2006, 11&#58;59 AM) [snapback]66468[/snapback]</div>
    There is a 6.5l 1/2 ton z71 out here where i live. They came from the factory like that too. This isnt the frist one i have seen either so maybe asside from stiffer front springs and suspension pieces i dont think the weight will be a problem considering that the 6.5 probably out weighs the d max by a little bit since the dmax has aluminum heads. Ill look at my buddys truck, hes got a 1 ton waiting to put in a rebuilt 6.5l I have a 1/2 ton truck waiting for me to get off my ass and build a motor for it so i will look today and see the differences in the two frames. Im sure if any difference the front crossmembers will be different. You can solve that with a 4x4 frame though. That would be cool to see a d max in a 1/2 ton 4x4. 4 wheel burnouts&#33; you will probably need 4wd just to keep the tires from spinning or put 20" wide tires in the rear. 4wd or not i think it would be a smokin fast truck
    I HAVE A 94 EXT CAB SWB 1/2 TON WITH A 6.5 TURBO DSL. IT RUNS STRONG FOR WHAT IT IS. I KNOW THE 6.5S WERE NO SHOW BOATS , BUT IT HAS LASTED THIS LONG AND RUNS GREAT. IT PULLS LIKE CRAZY, JUST NOT FAST.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
