Results 1 to 10 of 12
Thread: How would these wheels look?
    Jul 2005
    Loganville, GA
    I am starting a new project it is a 2003 Sierra V6 that will be getting a LS1 soon but for now I need advice on wheels.
    Which one of these would yall like to see on the new truck? Im going for the Corvette Theme
    THese are all corvette wheels so I dont know if they will fit but I think I can adapt them somehow
    http://66.56.95.102/z061.jpg
    http://66.56.95.102/z062.jpg
    http://66.56.95.102/z063.jpg
    http://66.56.95.102/truck1.jpg
    http://66.56.95.102/truck2.jpg
    1999 GMC Sierra Z71 Ext Cab, True Dual Flowmasters with X-Pipe, True Flow Intake, MSD 8.5 Superconductor wires, 180 Thermo, TB Bypass, Optima Battery, Synthetic All the way around
    http://i139.photobucket.com/albums/q...7787/Truck.jpg
    http://66.56.95.102/z063.jpg id say those if you were going to lower it any.
    Aug 2006
    LAKECHARLES, Louisiana
    Good luck searching! I have been shopping around for some for my truck and they only make them in five lugs so far. If you find them let me know.
    2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
    You're going to need about 2" of spacer to bolt those onto your truck axles. Motorsport Technologies can build you adapters but they are major pricey going from 6 to 5 lug.
    Aug 2006
    How well do they hold under torque? I had some on my 97 mootang gt and when I was doing a burnout for the ladies at our civic center my drivers rear tire shot off at bout 200mph.
    Aug 2005
    St. Anthony, Indiana
    Jul 2005
    Loganville, GA
    Yea I found the 2" conversion adapters for 100 each but wont that put the wheel to far out fo the fender
    Vettes have a way positive offset. I have 2" spacers on my 93 to fit the 18x9.5" vette wheels.
    Oct 2005
    Houston, Tx
    i like em
    What you need to do is measure the distance from your stock wheel's mounting flange to the outside wheel bead and compare that to a Corvette's offset.
