Results 1 to 7 of 7
Thread: e fans and harness
    Jun 2006
    Ok well i Just found out some crap that the W4m 87 tune does not help performace or gas mileage straight from jesse. So i have a pair of ls1 fans and for sale with a brand Nelson wiring harness. I am looking to get 175 for both. I have no use for them anymore since I returned my PCM. let me know. thanks
    May 2006
    Waco TX
    <div class='quotetop'>QUOTE(ltn &#064; Jul 5 2006, 03&#58;36 PM) [snapback]57194[/snapback]</div>
    How easy are they to install?? With a stock tune will it work?
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Jul 5 2006, 04&#58;04 PM) [snapback]57197[/snapback]</div>
    It&#39;s cake to install. Hardest thing is getting the old clutch off and getting that tiny little pin on the harness pushed into the 42 slot in the PCM.
    You&#39;ll need to fab a couple of brackets to hold the top of the fans in place. Bottom stays put without any fasteners.
    You&#39;ll need to get Pin 42 turned on. Allen can do it for you - not sure who else can do it.
    P.S. That&#39;s all based on my experience with mine, I&#39;m not sure how the SS is set up - I would assume virtually the same.
    Jun 2005
    Round Rock
    Same. Red, get the &#39;05 fans since you should already have the 34" radiator, inside to inside of core.
    Not to dis your sale but they are easier to install on a 28" radiator....
    Yeah, the LS1 fans are nice on a 28" radiator even though I had them on my 34" radiator in my 92 C1500. I have the 2005 factory electric fans in my 93. Yeah, they fit Billy.
    Jun 2006
    they work fine on the 34" rad and they are not that hard to install. u need 2 pieces of 1/4" metal 2 nuts and 2 bolts and a drill. It seriously took me a max of an hour. the stock fan was the hardest to get off.
    o yeah if u want to just by the fans they are 120 shipped.
    An alternative way to intall them is to use the through the radiator zip straps they sell at the zone. No brackets are needed that way and it holds them flush to the radiator. Just drill some holes through the plastic shield and draw the fans onto the radiator using the zip fasteners. Those type fasteners are used to hold aftermarket fans to radiators, too.
