Results 1 to 10 of 14
Thread: 80lb injector tuning
    San Antonio, TX
    Just got done tuning JJ's yellow STS truck after a few upgrades. With a fuel cell, good lines, Aero Pump, and 78-80lb injectors, this thing kick ass!!!
    The injector flow rate is now at 52% and fuel pressure stays at a strong 58psi.
    The stock 6L is pushing 14lbs of boost in third, so hopefully we'll see some 11's from it.
    This truck definitely hauls ass.
    I tuned this truck in speed density mode and it works very well. Nice start ups, great drivability and holds a solid 11.2 a/f ratio through all gears.
    Once a truck gets this far, there's no other option.
    Not sure what this post is about, lol, just figured some of the info would helps someone.
    allen
    Jan 2006
    San Antonio
    Right on.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Sounds promising. Now for some logging at the track
    Jan 2005
    Conway, AR
    Yeah Allen I was wondering if you actually did much SD tuning. Do you use the 1bar OS? I see guys all the time over on the Hptuners forum running SD, but I was unsure how often you used it. Is farmtruc going to use an SD tune?
    Chris
    Apr 2005
    belton, tx
    [size=6]MY TURN!!! MY TURN!!! MY TURN!!!
    Can't wait for mine to be ready. Let me know if I can get it this weekend.
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Nov 2005
    ohio
    nice work Allen!, i d love to ride in JJ's truck! thanks for the info, WE can only benefit from your research!
    Jun 2004
    george west texas
    good deal allen...getting all this sd tuning figured out only means you will have plenty of good info when my '93 rcsb gets over there for earth shattering power
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(bud8fan &#064; May 12 2006, 01&#58;18 PM) [snapback]52875[/snapback]</div>
    good deal allen...getting all this sd tuning figured out only means you will have plenty of good info when my &#39;93 rcsb gets over there for earth shattering power
    San Antonio, TX
    Ya, the truck will be SD tuned, especially at 18psi, hehehe.
    Well, JJ&#39;s truck didn&#39;t run so good. We came to the conclusion the stall converter is just too damn loose and doesn&#39;t load up the converter.
    He has a 3200 stall in it, and at the light, I can easily get 5KRPMS&#33;&#33;&#33;&#33; from the converter. It just stays at the high rpm level and doesn&#39;t pull very strong. This is through 1st and 2nd.
    Once this bad boy hits 3rd gear, the converter locks, 14psi comes in and it&#39;s gone&#33;&#33;&#33; When the converter is refreshed, all gears should do this and low 11&#39;s are in reach.
    We&#39;ll get it, definitely next time.
    see ya,
    allen
    Jun 2004
    george west texas
    i read somewhere else that another guy was having trouble with a 3200 flashing upwards to 5000 rpm&#39;s....that way loose right there....
