I haven't had a chance to read and see if my 97 has this but the 2002 PCM reads fuel tank pressure voltage. Did any of you with the OBS truck conversions have to disable this from the DTC's? If I don't need this I'll disable and set the error code to 3. P0452 is the only code I'm throwing so far.
Oh, with my tach reading lower than normal, this is probably why my tranny never shifted correctly. It felt like it was staying in 1st gear. I know my RPM's were showing under 1500 when they were really around 3000.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
