Results 1 to 10 of 17
Thread: New Interceptor Gauges
    San Antonio, TX
    Hey Guys, I just got a new shipment of the NEW and IMPROVED Interceptor gauges.
    These gauges are basically a tiny laptop with logging abilities rolled into a small 2 1/16 gauge.
    It will monitor everything needed to ensure your tune is running just right! It's great for guys running a mail order tune and wanting to give feedback to their tuner. It's also very handy if you're just wondering what the engine is doing.
    Here is a list of parameters available:
    RPM
    MPH
    Intake Air Temperature
    Mass Air Flow Sensor Frequency
    Mass Air Flow Sensor (lb/min.)
    Engine Coolant Temperature
    Injector Pulse Width (bank 1 and 2 if supported)
    Long Term Fuel Trim (bank 1 and 2 if supported)
    Short Term Fuel Trim (bank 1 and 2 if supported)
    O2 Sensor Voltage (bank 1 and 2 if supported)
    Manifold Pressure in PSI (Boost pressure for factory
    turbo/supercharger applications)
    Ignition Advance
    Knock Retard
    Engine Run Time
    Battery Voltage
    Transmission Temperature
    Idle air Control Counts
    Throttle Position Percentage
    Throttle Position Voltage
    Engine Load
    Oil pressure (some 8 cylinder engines)
    Fuel economy (MPG)
    Horspepower
    Two user configurable analog inputs
    -new features that will come in very handy!!
    fuel economy
    horsepower
    two user configurable inputs
    shift light
    Here's some more info on the gauges: AeroForce
    These gauges are $229
    I have two types right now. Black face with Black or Silver bezel.
    thanks,
    allen
    Hot Damn! If they figure out a way to download log files that is going to be the hottest thing going out there!
    hypothetical question: say i want to swap engines along with pcm. will the interceptor gauge be able to be used after the swap?
    San Antonio, TX
    Ya Red, it sure will. They do have a playback ability.
    You sure can ducky! All obdII trucks can use them.
    thanks,
    allen
    Nov 2005
    ohio
    DAMN!, i bought mine to soon, this is the best gauge on the market hands down!
    Mar 2006
    Indy
    I guess, when the tax check comes in, im getting one.
    Mar 2006
    Indy
    Tax check came in, need to pay off the credit card, and I will let you know to when I can order one, soon.
    San Antonio, TX
    sure, i'll be here when you're ready.
    thanks,
    allen
    Jun 2005
    Way up in North Dakota
    Cool
    I sent a money order by snail mail last week now I just need more duct tape to put it on my dash
    2002 GMC 1/2 ton Sierra,4WD, Xct cab, camed, mid-length headers, Nelson tune, electric rad. fan, trany cooler, Heavy 5750 lbs with topper.
    San Antonio, TX
    <div class='quotetop'>QUOTE(metalchips &#064; May 8 2006, 09&#58;14 PM) [snapback]52494[/snapback]</div>
    Hey, whatever works, as long as it&#39;s functional right, lol.
    thanks,
    allen
