I've been going back and forth on the turbo decision. Do I do one big turbo or two smaller ones?
Well, after throwing around ideas for a long time, I just dove into it and decided to do twins. This stuff is a lot easier than what I was expecting. This only took 2hours, but it's also only tack welded.
It's not much, but I built a simple header for the drivers side. I figured if I could build a header for the driver side and get it around the steering and engine mount, I'd easily be able to build the passenger header. The passenger side has all kinds of room.
The header is made from 16g mild steel, but it's just a mock up. The collector will be cut off, about 2 more inches, then I'll add a 3" U-bend on top of it, weld the flange on and then bolt the turbo on.
The passenger side will look the same.
Once I get it all done, I'll rebuild it in stainless steel and finally be done.
The mock up has plenty of room, the plugs clear and I should be able to route some custom plug wires around the headers.
Here are a few pics.
Stage7
Any suggestions on turbo sizing, wastegate options, intercooler routing, websites for parts, is greatly appreciated!
allen
