Results 1 to 6 of 6
Thread: Which Welder?
    Jan 2006
    Las Vegas, Nevada
    The time has come for me to bite the bullet and buy a wire feed welder for my home garage and I'm looking for some input from any of y'all familiar with the trade. There seems to be a price and power breakpoint between 110V and 220V models that I have been having a hard time deciding between. I plan on using the welder for sheet metal panels, occasional light frame repairs and bracket and mount fabrication. Nothing too serious and it won't be used that often.... I expect it will sit idle for months at a time.... The question is, shoud I go with a 110V 130 amp unit or a 220V 180 amp unit? I have power available for both but the 110V package is cheaper and can plug in anywhere (including friends garages) but the 220V unit seems more capable. Any knowledgeable guidance would be appreciated on both my requirments and any brands to avoid. TIA, Andy
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    Dec 2005
    san antonio & victoria
    hobart is really good for the money.
    i'd definitely go with the 110v. it's plenty.
    2007 Victory (Polaris) Hammer 100ci/6spd/stepped pipes/power commander/torque tube intake/lowered
    2010 Malibu 3.6vvt
    2000 Formula, 6.0, LS3 heads, stall, etc, etc - SOLD
    2008 CCSB 4.8 - SOLD
    2003 2500HD 6.0, long tubes - SOLD
    1999 ECSB 5.3, cam, stall, 2/4 drop, 05 wheels - SOLD
    I've used a Lincoln 110v unit for the last 8 years. It's more than paid for itself. Be sure you buy it with the shielding gas setup instead of the flux core. I've welded steel up to 3/16" with it and have had no problems with penetration. The light stuff takes a more delicate touch but it's not too bad.
    Dec 2005
    Dallas, TX
    dont know technical stuff but my buddy has a 110, i like cause that means i can use it when i need one. LOL I wanna get me one but i dont use it that often. I really like the stick a little more than wire, guess cause it takes skill.
    besides all that... id say go with the 110... should be strong enough for the stuff you have to do.
    2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
    9.5 in the 8 mile
    6000K xrtalight h.i.d kit
    San Antonio, TX
    110v will be plenty. I use mine for all the tasks you mentioned and then some. It'll weld frame to 18g tubing.
    I have the lincoln 110 from Home depot, the 135amp. It's about 3-4 years old and I use it every month.
    I do use the core flux instead of the gas. I guess I'm just used to it, but it welds just fine and the welds look pretty damn good imo.
    good luck,
    allen
    Dec 2005
    Chicago-ish
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
