Results 1 to 10 of 11
Thread: F.S. 5.3 with extras
    Nov 2005
    SOLD!!!!
    '00 5.3, '02 Ls1 heads, Patriot Gold double springs w/ titanium retainers and new seats and seals, SLP cam-234/228 .576 .571 113lsa, new head gaskets with new head bolts, cam and springs have only 500 miles on them, comes with oil pan, but has small crack,new oil pan gasket, no front or rear cover or valve covers. never had N20 run through it.
    Motor runs very strong. $1000.00 Motor is in DFW area. Prefer local p/u, but may ship. Can hear the motor run before buying.
    front two springs are the Patriots. Pic was while changing the springs.
    SOON TO COME!!!!
    Parting out the Beatertruck?
    Nov 2005
    Well, I am getting a truck thats in alot better shape; a 1985 1/2 ton Sierra step side. Alot of whats on the old truck is going on the new one, but I am selling the long block to pay for a few other things. I will post some pics in a few days. This truck has all new front suspension with urathane bushings and drives much better.
    Once I get a few things changed, I will try and get a 6.0 core to start to build for it.
    The body of the old "beatertruck" will be for sale soon for $600.00.
    SOON TO COME!!!!
    Nov 2005
    ohio
    good deal on that engine! Looking foward to beater truck #2!!!
    Aug 2005
    Curious, what is that on the crank snout?
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
    Dec 2003
    Newark, Tx.
    When we build a motor, we use some speciality tools to ensure proper assembly.
    The tool on the end is a front cover alignment tool. The front cover will "float" some. That tool aligns it.
    Yep, that's a genuine GM precision alignment tool for the proper installation of the front cover. There's one for the rear cover and oil pan, also. I use the poorboy method, put the cover on loose, draw the crank pulley on, install the oil pan without the gasket and snug it down, loosen the cover bolts, tighten the bottom bolts through the pan into the front cover and then tighten the cover bolts to specs. I know it's not the recommended way to do it but I've never had a leak anywhere but a valve cover gasket that fell out of the groove during installation.
    Apr 2006
    what times have you run with this engine in the 1/4?
    4.3L 00' sierra AKA slo (the W still hasnt caught up yet)
    gibson exhaust system
    Hypertech tune
    Apr 2006
    and how much hP and torque does it put out?
    Hypertech tune
    I think this is the engine that is going into Alton's 93 chevy SWB truck.(bud8fan)
