Results 1 to 10 of 13
Thread: True Flow Intake - Rough Idle, Stalling - Any Ideas?
    Mar 2006
    Mesquite
    Well, my problem is stated above. I'm about to take a drive for a couple of hours and see if things get regulated by the PCM, but thought I would post and see if any of the experts out there had any input? Just to save time, I installed exactly per the instructions, everything is tight, etc. Any ideas?
    Nov 2005
    San Jose CA.
    Possible you damaged the MAF during the exchange?
    626/762 2005 SIERRA 11.34@119.81
    My other ride is a '91 Electraglide custom.
    2003 5.3L? You did not descreen the MAF, did you? Did you pull any wires loose in the MAF connector?
    Mar 2006
    Mesquite
    No to both questions. It seems to be runnning better the more I drive it. Every once in a while, I'm still getting a little bit of a rough idle. Wondering if it just needs time to adjust?
    Nov 2005
    San Jose CA.
    dont know then...I didn't have any issues when i changed up intakes.
    Nov 2005
    ohio
    i had a true flow intake before i got the turbo, had no problems at all, it probably needs to learn
    Mar 2006
    Mesquite
    Turns out when I reattached the neg. cable, I was supposed to start the truck with all accessories off and let the computer "figure out" the fuel requirements...Live and learn. Runs good now.
    HotRodV6 Guest
    I know this is an old thread, but how do you like the true flow intake??
    Mar 2006
    Mesquite
    Well I sold it when I went back to stock. I personally don't enjoy oiling the filter, so I wouldn't get it again. That aside, it served the purpose. I like my new route better - even if it is home made.
    HotRodV6 Guest
    i thought the true flow was a foam filter, so no oiling?
    Im looking at the different CAi's for these trucks, and cant make up my mind which one i want, im sure they all do the same thing, but there is a alot of differance in price among them. Im liking the volant the best
