Results 1 to 6 of 6
Thread: MAF screen
    Apr 2005
    Alright, I havent been here for a while sorry. Im just starting to do my own tuning with HPT. Im haveing some issues, especially until my temps come up, but I have some low speed issues too, I think may be related to teh MAF screen being removed. I plan to eventually go to SD, when I do, will the MAF screen even matter? I wouldnt think it does, because you arent using it, but Im still new to this, so I figure Id get more opinions.
    Thanks
    2000 RCSB Z-71 6l swap 12.8 Gone but not forgotten
    2008 CCSB "tow truck" Slooowwww
    1999 RCSB "WRK TRK" 4.late but getting there.
    Jan 2006
    <div class='quotetop'>QUOTE(white1 &#064; Feb 1 2006, 10&#58;19 AM) [snapback]42994[/snapback]</div>
    Thanks
    What year is your 6.0? My brother had a problem when he removed the screen, he had to get a new maf, so he went withthe Granetelli, it&#39;s been set up to not be so lean withthe air intake on.
    BTW his is a 05 6.0 HO like mine.
    05 Escalade STS GT67 5Lbs
    06 G35 6MT SEDAN
    92 Gmc Typhoon # 46 (Sold, gonna miss her)
    92 GT Basic Mods
    Just do the SD tune and be done with it. Then you can 86 the MAF all together.
    San Marcos Texas
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Feb 1 2006, 02&#58;08 PM) [snapback]43036[/snapback]</div>
    I think I want to do that next&#33; I&#39;m getting a 2 bar MAP.
    Jan 2005
    Conway, AR
    yeah get the 1 bar MAP white1, it will enable you to use both octane tables as well as a couple other tables they add with that OS. You can remove the MAF and put straight through tubing in its place, but if you do that get a stand alone IAT sensor and tap into the intake tube and MAF plug.
    Chris
    Apr 2005
    <div class='quotetop'>QUOTE(TurboSlade &#064; Feb 1 2006, 12&#58;52 PM) [snapback]43025[/snapback]</div>
    I think its an 02, I really dont remember. Mine doesnt run lean, its pig ritch right now.
    <div class='quotetop'>QUOTE(chrisj6 &#064; Feb 1 2006, 07&#58;37 PM) [snapback]43105[/snapback]</div>
    Chris
    Why would I need the 1 bar? Im new to tuning, but I thought that was more for FI applications. Also I dont care about the other octane table. All I ever run is premium. Its .20 cents more per gal x 26 gal.(at dead empty)=&#036;5.20. Ill spend the extra &#036;5 for the extra performance.
