Results 1 to 10 of 22
Thread: Engine harness almost done
    San Antonio, TX
    I wanted to show off the new engine harness but there's not much to look at lol.
    I was like "where's the harness" I guess that's a good thing.
    If you look close you can see the harness done on around the intake manifold only.
    The mess behind the intake will be cleaned up and shrinked, then ran through the firewall, directly behind and below the intake. The harness should be invisible.
    Here are some pics. The last pic really show's how clean it is!
    Engine harness, almost done
    Anyone need a custom harness done?
    allen
    Keep the updates coming! It's starting to take shape and looks good. What connects to the fuel rail pressure tee?
    Nov 2005
    ohio
    nice work , that wiring can be tedious! hidden wiring looks the best.
    Jan 2006
    San Antonio
    Nice job.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    San Marcos Texas
    <div class='quotetop'>QUOTE(farmtruc &#064; Jan 31 2006, 07&#58;51 PM) [snapback]42898[/snapback]</div>
    I wanted to show off the new engine harness but there&#39;s not much to look at lol.
    I was like "where&#39;s the harness" I guess that&#39;s a good thing.
    I don&#39;t see it LOL&#33;
    It is&#33;
    Here are some pics. The last pic really show&#39;s how clean it is&#33;
    allen
    Hell yes&#33;
    Dec 2003
    Newark, Tx.
    Allen, I&#39;ll be needing one of those soon. Make mine with LS1 style injector connectors please. Looks great.
    Where are you going to put the pcm? I have the truck holder and cover, but not sure where its going to go.
    San Marcos Texas
    I think I want to move my PCM under the cab. I have lots of room where the fuel tanks used to be&#33;
    Jul 2005
    Galesburg Il
    allen
    Allen ,
    PLease let me know when you are ready to sell these. I want one. For sure.... if I can e assured that it&#39;s just plug and play. I&#39;m clumsy as hell.
    Got my 2 pulleys today. The truck still wont&#39; rev above 5600. Falls flat on it&#39;s nose at 5600 and acts like the rev limiter is still activated. Yesterday it would lot even shift because it wouldn&#39;t rev high enough.
    Anyway... I want the harness.
    2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt&#39;s into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
    San Antonio, TX
    Thanks for the comments, John, my help and brother does an awesome job with wiring&#33; The pcm is going to be located under the dash, probably near the glove box. I have plenty of room in that area.
    I wish the truck intake was so damn ugly. Later on, I&#39;m getting a nice sheetmetal intake made, then it&#39;ll look awesome&#33; This week we&#39;ll finish up the harness, install the fuel pump harnesses, and get the starter and battery wired up.
    I think I&#39;ll rework the GTO harness and shrink everything, it looks much nicer than wire loom.
    GMCwants and TRT, Come on over guys, we can build you one&#33; I promise you nobody will pay more attention to detail then us&#33; We just did a &#39;70 Camaro LS1 swap harness and it&#39;s also invisible.
    Jim, your truck is a mystery, lol, JK, I&#39;ll get a hold of you this week and see if we can&#39;t figure it out.
    We can rework a stock harness to look like this, but, I can&#39;t say it&#39;s plug and play. The factory harness goes to so many places, I&#39;d have to have your truck here to rework it. I&#39;ll see what I can come up with. I&#39;ve always thought the truck harnesses were very messy.
    thanks,
    allen
    Jul 2005
    Galesburg Il
    <div class='quotetop'>QUOTE(farmtruc &#064; Jan 31 2006, 09&#58;08 PM) [snapback]42939[/snapback]</div>
    thanks,
    allen
    Boy have you got that right... mystery and messy&#33;&#33; Wish I could get it there, &#39;cause I&#39;d love to have Jon work his magic on the harness and you work yours on the tune... in person, but it&#39;s about 17 hrs one way&#33;&#33;
    Thanks for the reply Allen. Looking forward to hearing from you re: the rev limiter. Regards, Jim
