How has every body been. I havent been on in a long time ive been moving around and havent had access to the web. so howdy.
Any way i got me another toy about a month ago. I got a sweet 67 GMC swb really clean but needs a little body work though and it only has one spot of rust and that is on the inner fender well.
When i got it it had a 383 stroker in it with a T400 tranny and 3.73 gears. well i burnt the 400 up so i swapped it out for a T350 with a 2000 stall TC
this thing screams. now im working on putting a 12lbs boost turbo on after i stick my set of 375 double hump heads on it.
Right now the motor has a small 284 dur. cam and 882 heads so it is rather choked downright now but i still get a third gear rubber.
Ill post up some pics tomarrow if i have a chance before i go to the gym after work.
hit me up n tell me what you think.
thanks
Daily driver: '97 Z-71 reg. cab, electric fans, dual bats, K&N cold air, custom built muffler, and your standard blue light special equip...
My Baby: '67 GMC swb small back glass. 388ci stroker, old school bowtie heads est. 450hp, scat steele crank, eagle H beam rods, and Keith Black pistons, but only pushing 10:1 compression, fed by an Edelbrock 750 carb. THM350 trans. shiftkit w/manual valve body, 2800 stall going out back to some highway 3.42 gears, tubbed.
