Results 1 to 10 of 11
Thread: Bad gas mileage
    Mar 2004
    SOUTHwest Georgia
    Seems my gas mileage has gotten way worse lately. Changed plugs to TR55's and fuel filter and used top engine cleaner....
    wtf would be making it go down besides my foot? I don't drive agressive all the time
    http://i14.photobucket.com/albums/a3...tt/firesig.png
    1998 ECSB Z71
    285's and exhaust.
    Apr 2005
    O2 sensors? It helped on my '99 after 11X,XXX miles
    Gone, but not forgotten!
    Aug 2005
    Yes, the 02 sensors get lazy with high mileage and will lower fuel economy.
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
    Mar 2004
    SOUTHwest Georgia
    Which ones? The rear ones aren't even turned on b/c of my cats being gone, so would I would replace just the front ones rite?
    1998 ECSB Z71
    285's and exhaust.
    Jan 2005
    Conway, AR
    My gas mileage has been really bad lately also, I just think its a case of winter gas mileage.
    Chris
    Mar 2004
    SOUTHwest Georgia
    It just seems like it happened overnight. I was getting around 400 miles a tank now its down to 230 or so
    1998 ECSB Z71
    285's and exhaust.
    Yeah, that sounds just like dead O2 sensors. Mine did that too until they were replaced. Driver side front unit checked good but wouldn't work worth a damn.
    Mar 2004
    SOUTHwest Georgia
    I know these engines don't work well with Bosch plugs, but are their o2 sensors okay to use?
    how do you check it to see if its working.?
    And I know this is stupid, but if the fronts go bad, the rear ones arent turned on, could I swap them to the front to see if it makes a difference, or are they different kinds?
    1998 ECSB Z71
    285's and exhaust.
    Jan 2006
    San Antonio
    I have never had any probs with bosch sensors. I agree on the plugs though.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Jan 2005
    Conway, AR
    I think the problem with using the rears is going to be the length of the cable, I dont think they are long enough to be used in the front.
    Chris
