Results 1 to 9 of 9
Thread: Need Yank 2400 or 2600 converter
    Anyone know where I can find a Yank 2600 Torque Converter in stock for
    a 1999 Chevy Silverado with 5.3, 3.73 gears.. Only minor mods to truck.
    Yank is closed until Jan 12th due to flooding.
    I am repairing my tranny as we speak, wanted to put in a new converter
    while we were at it.
    Thanks,
    Brian
    A lot of the guys are getting custom built convertors. Allen can tell you who built his for his application and it's not any more expensive than a Yank or Vigilante(what I'm running).
    Apr 2005
    belton, tx
    JEGS has the TCI ls1 converters. I use the "breakaway" stall and it's good for 2500 stall. I want bigger though.
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Thanks for the comments fellas..
    STS
    Anything you like/dislike about the TCI Converter.
    I can't afford the vigilante.
    Nov 2005
    ohio
    i havent heard any thing good about the tci converters, i talked to 2 tranny rebuilders who think they lack in strength and durability, but thats just what i heard and you know everybody has a diff opinion on this, plus they seem to be as much as some converters ive seen from fuddle and others.
    Apr 2005
    belton, tx
    no probs yet..however, we'll see when the new motor goes in with the extra HP and Boost. I'm guessing all the weak areas will show rather quickly.
    There is a nice Vigilante for sale on LS1Tech for $400. I can't remember the stall though.
    Jun 2005
    Well I wish had my new setup coming, then I would sell you my YANK 2600 converter with about 3000 miles on it, but it's still going to be about a month before I'm ready to sell. Those Yank 2600 converters are perfect for a daily drivin truck that sees towing alot. Only reason I'm going to sell it cause I want to slap a 3200 in it when I order my built tranny. Good Luck finding one Check with Speed & Engineering. Or look into them Fuddle Converters.
    2002 Red Chevy RCSS (engine mods)- 05 5.3L, Procharger P-1SC 9lb.pulley, 80mm BBK TB, TB By-Pass, 38lb. Inj., AlkyControl Meth Kit, ASM L/T's, Magnaflow X-pipe, Borla's, FLT Level 5 4L65e, PI 3000 Stall, B&M Tranny Cooler, 3:73's, G-80, E-Fans, 160' Thermo. Custom Built Intake with K&N. WideBand 02 Sensor, DIXIE TUNED.
    Ok Guys. Trying to get my tranny back together.
    Posted the other day about my tranny and sprag problems.
    ZCould not get a yank in time needed so I finally found a
    Trail Blazer Torque Converter.
    Unfortunately the only one they had was part number: 24213393
    Which is for the 5.3 L. .. Anyone know what this will stall
    in my 1999 Z-71 with 5.3l and 3.73 gears.
    Anyone else used this part number converter in Silverado.
