Hello all,
I am sure that this question has already been asked several hundred times... but here it is.
I have a 1992 Chevy Silverado: single cab, short bed, 4.3L V6. I found a 1998 LS1 out of a Camaro on ebay. The engine includes the tranny.
Will this setup work in my truck. What will I have to change/mod to get this in my truck.
Here is the description:
You are bidding on a complete takeout LS1 engine/transmission combination with just over 70k miles from a 1998 Chevy Camaro Z28/SS. If you have been looking for a setup like this you will not find a better value anywhere. Damage to the vehicle was not severe and the engine/transmission are in good running condition for their year. This is the same engine found in 1998-2002 Camaro Z28, SS, Trans Am, WS6, 1997-2004 Corvette and 2004 GTO. Water pump, alternator, power steering pump, motor mounts, A/C compressor, EGR, starter, engine wiring harness, LS1 intake, exhaust manifolds, MAF, throttle body and PCM. This combination has the performance 4L60E automatic overdrive transmission.
Any advice would be extremely helpful.
BEN
- You may not post replies
- You may not edit your posts
