How hard is it to just change out the gears? I really need to get rid of these 3.23's
what size would y'all go?
3:90 all the way bizzatch
What size tires do you plan on running? That will factor into you gear selection. You don't want to run 4.10 on 26" tires nor do you want to run 3.23 on 32" tires.
Originally posted by RedHeartbeat@Dec 12 2005, 05:34 PM
What size tires do you plan on running? That will factor into you gear selection.![]()
Gone, but not forgotten!
how would you like to switch the whole rearend with mine? 4.10's with eaton posi
http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
04 GTO
Both Tuned By: ME
ITS EASIER TO CHANGE THE REAREND find a good used one and it might be about the same cost or cheaper than buying gears and paying for set up, plus a factory rear is set up the way it should be ,less headaches, good luck.![]()
really?? how many miles are on it? it's not gonna go boom is it? j/k, also i have drums on the back of mine. will they both just swap out?Originally posted by vv8@Dec 12 2005, 07:07 PM
plan on keeping it around 30.5-31" stock is 30.46, the tires i want are 30.5Originally posted by RedHeartbeat@Dec 12 2005, 05:34 PM
not sure on the back breaks, do a search and let me know, nope it wont blow its built to handle 700 hp lol
04 GTO
Both Tuned By: ME
I say 3.73
